2 members (Bill Hanlon, 52Carl),
87
Mod | | | Forums66 Topics128,094 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Good Evening, I have recently obtained two 3spd trannies, which have different markings on the left side of the case. I am looking to find out what the cast numbers mean. If someone can point me in the right direction, I would greatly appreciate it. They have the following cast into the left side of the case:
One looks like this The other looks so 591195 591195 GM1 GM2 41 D231 J247 Thanks, Richard
Richard J Patrick - 1946 Suburban
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | What do you mean by top loader? Do you mean a top loader like a Borg Warner or a 3 speed with a stick? | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | G'morning,
Sorry for the confusion. A tranny with a stick as opposed to a column shift or side loader. I beleive it to be from a 41-4? tranny, I will use it for a '46 Suburban. What I am looking to find out is there a difference in the gears denoted by the casting numbers? Thanks again, Richard
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Casting No. 591195 is correct for a Chev or GMC pickup from 41 to 47 first series. If both cases have the same casting numbers, they are the same. The other numbers are dates, etc. | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Hey There Shop Shark, Thank you most kindly. The other difference is the torque tubes?? (drive shaft couplers?) are different lengths. Would this be for different years or different models ie: 1/2 or 3/4 ton? Richard
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A 1/2 ton uses a full torque tube while a 3/4 ton uses a torque tube to the center bearing and open from there to the rear. A 1/2 ton in the 40's used a different U-joint at the rear of the transmission than a 3/4 ton. | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Hello Again, Thanks for the information. I believe either of the transmissions I have will work for my application. Now just ot get them cleaned and reconditioned. Into the Burb and away we go!!
All the best to all, Richard
