5 members (Gdads51, Nick in Manitou, FAST55, Bill Hanlon, dt235sd), 83 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
#743925 05/01/2011 9:00 PM
I was wondering what weight of oil to use in a 216 engine in a 1949 truck? mulit grade or straight 30 weight
Bennie
Ex Hall Monitor
Ex Hall Monitor
A modern multi weight is probably the best way to go. I run 14W45 in my '38. Many run 10w30 without issues. The problem with straight weight oil is it's ambient temperature dependent.
Like Tiny said I think The multi-vis oil is the easy way to go, although I've used a 20w-40 in motors during the hot season because of 10w- being so light in the hot season for an old motor.
It also has become an issue of what you can buy as a lot of the older types of oil are getting harder to find easily.
With newer engines requiring 5w-20, 5w-30, it is becoming more difficult to find the older weights of oil.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Thanks for your feedback
