1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74373 03/07/2007 3:04 AM | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | Ok, my curiosity has gotten the bst of me, im in the process of stripping the inside down, i havent gotten back to the gas tank, but what do i have to go through to take the gas tank out, it isnt ard is it? thanks!
- Zach Morris
#74374 03/07/2007 3:30 AM | Joined: Jan 2007 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 172 | The '65 in cab tank was not easy. I replaced the gasket on the cab, the filler neck, the rubber tube, and the tank.
I put in the gasket on the cab. Then put the filler neck into the gasket. I put the rubber tube on the tank and cinched that down. Then I put that into the cab and had to create a new joint in my wrist to get the rubber tube over the filler neck and cinch down that screw clasp.
That seemed the best way to me...took about 30 minutes or so...and only a couple of cuss words.
I have seen pics of others that have the filler neck already in the rubber tube, but I can't figure out how they get that to fit into the gasket since it is a tight fit.
Dave 1965 Chevy C-30 1-Ton "Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching." | | |
