5 members (39suburban, 2-Ton, pauld, 2 invisible),
160
Mod | | | Forums66 Topics128,186 Posts1,057,305 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74369 03/07/2007 2:33 AM | Joined: Feb 2007 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 18 | my buddy just picked up what he was told was a '69 half ton rear end for his truck. (his truck is a '53 1/2 ton with 350 and 4 speed manual tranny from a '74 1/2ton)
apparently it was basically given to him for free. but we cant seem to nail down what the gear ratio is, the net has conflicting/confusing info. didnt find any sort of part number either. and dont have the truck it came off of for reference.
he's worried about the 3.7 being too low for highway driving and is hesitant to install. anybody know what that ratio was if it is from a '69 half ton?
if it is a 3.7, is that too low? i remember doing freeway 70mph or so in a '68 half ton with my uncle when i was a kid so it cant be that bad right?
'53 3100 on '93 S10 chassis- 4.3V6 +4L60e '51 suburban TBD
#74370 03/07/2007 2:49 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The code will be stamped on one of the axle tube, couls be either side, on the bottom adjacent to the carrier housing. It'll either have 3.07, 3.73, or 4.11. If it's a 3.73, it may not be too bad depending on what tire size that's going to be run. If he's not totally committed to the 4 speed, perhaps a T5 might be a better option. That'll get an overdrive gear for highway use.
Bill Burmeister | | |
#74371 03/07/2007 5:31 PM | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | hey Kidd, Why don't you just raise the rear end off the floor and turn the drive shaft one complete turn and count how many times the axle turns? | | |
#74372 03/08/2007 6:24 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | a 3.73 with really tall tires will work.go to www.randysringandpinion.com .they have a calculater to estimate rpms. | | |
