1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 23 New Guy | | New Guy Joined: Dec 2005 Posts: 23 | When swapping out the rear axle of a 47-53 3100 pickup, the rear axle is not supposed to be directly over the alignment pins on the leaf springs. Anyone remember the distance that the offset should be? I hope to make some short spacer blocks to go under the spring perches that will keep the offset. | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | I've heard of people swapping the spring main leaves end-for-end which puts the center bolt closer to the middle of the wheel opening. It's also possible to drill extra holes in the rear end mount pads to move the centerline of the axle tube forward or back for a little fine-tuning of the wheel center position. Jerry
