| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74355 03/06/2007 9:21 PM | Joined: Aug 2006 Posts: 8 Junior Member | | Junior Member Joined: Aug 2006 Posts: 8 | Can you fit a power steering pump to a GMC 270 straight 6? | | |
#74356 03/06/2007 9:57 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dwg49gmc, of course it could be done, you would have to purchase or fabricate brackets, the original 6 cylinder power steering pumps were driven off the back of the generator, hope that helps. | | |
#74357 03/07/2007 4:12 AM | Joined: Aug 2006 Posts: 8 Junior Member | | Junior Member Joined: Aug 2006 Posts: 8 | Thanks for the info. More research is definitely needed. | | |
