0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#743060 04/28/2011 3:17 AM
I have a couple of distributors from 80's Chev p/u with an I6.I've read articles that say this distributor can be modified to fit the 235/261 engine.Is there any interference because of the larger diameter cap?Besides running a larger wire are there any other mods that need to be done to make this work?
oleschool #743069 04/28/2011 3:47 AM
The HEI housing doesn't fit deep enough into the stovebolt engine to get a good shaft engagement into the oil pump, so the positioning collar on the housing needs to be machined or ground off and the clamp that holds the vacuum advance from the stovebolt distributor is used to adapt the HEI to the block. Once the mechanical fit is right, run a heavy wire from the ignition switch to the HEI power plug- - - - -I like to use a #10 wire to carry the necessary current, just like GM did when they made the factory wiring harness for the HEI. Obviously, the electrical system has to be 12 volts.
The diameter of the new distributor is quite a bit bigger.Does this pose any clearance issues with the rocker cover?Thanks for your help.
oleschool #743107 04/28/2011 7:01 AM
Nope, there's just enough clearance to let it fit without touching the pushrod cover.
i did one and it works great.
there is a illustrated write up in the tech
tips. philip
