5 members (3B, Otto Skorzeny, 55shaker, rick46ia, 57 Drifter), 73 guests, and 1 robot.
Topics128,023
Posts1,055,365
Members48,420
I have a '51 Chevy 3604 and I am cleaning the engine side cover. Do I dare sandblast the interior side of the cover to remove all the carbon built up over the years. :confused: I plan on blasting the exterior surface. I used a wire brush on my drill one the interior side and got most of it. I would imagine blasting it would pit the surface too much. I won't do anything until I get a lot of feedback. Thanks, Wada.
Cleaning it or sandblasting it will not harm it in any way however do not paint it as it could come off and get in the oil. Solvents should be all thats needed now however to finish it.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I think you're right 53moneypit, my gut tells me just to clean it as best I can without sandblasting it. I wasn't planning on painting it. I'm just a perfectionist I guess. Of course, then I would have just bought a new one. Thanks for your input. Wada
Soak it in a bucket full of lye for a week or two. It will remove all the crud but leave the metal alone, then just rinse it and coat it with motor oil to keep it from rusting.
Paint & Body Shop moderator
Ex Hall Monitor
Ex Hall Monitor
Good advise above. One possible problem with sandblasting is it's easy to warp the metal from the heat generated. Sometimes blasting is necessary but always be careful about heat buildup.
I could be all wet on this, but the 'warp' deal on sandblasting isn't from heat but rather the little granules of sand (or whatever) 'peening' the face of the material and spreading it out...just like beating on it with a hammer.
Stuart
blasting seem to make things grow so be carefull...doc
Ex Hall Monitor
Ex Hall Monitor
Could be stretching the metal or maybe a combination of both. The local sandblaster is the one who told me it was heat buildup. ohwell
Sand blasting motor parts makes me nervous. You sure don't want any sand inside the motor when you start running it!
I'd rather soak it in lye or have it hot tanked or something.
