9 members (cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible), 109 guests, and 4 robots.
Topics128,062
Posts1,055,847
Members48,428
#74291 03/05/2007 5:43 PM
I have a rear main seal leak on a 81 267 V8.Can this be repaired without pulling everything apart?Is it possibble to slide a new one in without taking the motor or crank out?Thanks guys
Lothar
#74292 03/05/2007 6:30 PM
You can remove the pan & rear main cap & loosen other maincaps. A small punch(using hand pressure) can be used to start the seal moving, pliers to rotate it out. Soak the new seal in oil befroe installing. There is also a "Chinese finger" tool that may help, but I have never used one. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#74293 03/05/2007 6:35 PM
Thanks Brian,that sounds simple enough.I'lld do that,the first non rainy day I get.
