8 members (Donf, tclederman, C10 - C90 Bill, HandyAndy, DoubleB, Otto Skorzeny, Gdads51, 1 invisible),
44
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74291 03/05/2007 5:43 PM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I have a rear main seal leak on a 81 267 V8.Can this be repaired without pulling everything apart?Is it possibble to slide a new one in without taking the motor or crank out?Thanks guys Lothar | | |
#74292 03/05/2007 6:30 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | You can remove the pan & rear main cap & loosen other maincaps. A small punch(using hand pressure) can be used to start the seal moving, pliers to rotate it out. Soak the new seal in oil befroe installing. There is also a "Chinese finger" tool that may help, but I have never used one. Brian | | |
#74293 03/05/2007 6:35 PM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Thanks Brian,that sounds simple enough.I'lld do that,the first non rainy day I get. | | |
