1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
I have a GMC 302 straight six, with a water pump that needs a new internal seal. I pulled off the pulley, pressed out the bearing and shaft, then removed the impeller. The phenolic seal has a crack in it. Are these parts available any longer? Any suggested sources would be appreciated.
I just found a kit on ebay, the vendors had carried the kits but now only see the complete pumps.
1946 1/2-Ton Chevy
I would install a pump if one can be had...doc
Do you know if any of the retail guys carry these? Any other suggestions??
