4 members (HandyAndy, Jon G, 2 invisible),
148
Mod | | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 33 | Hey All, When I drive my 1953 3600 around town after about 20 min. the brake pedal becomes stiff, loses play, but the truck will still stop i just have to use more pressure on the the pedal. I could not find this topic in previous post. Help me out Thanks | | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | Hi Cardo, You may have a bit of water in the brake fluid. When it get hot creates a small amount of pressure in the lines. Just a thought.
Chris
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Brakes are adjusted too tight.
Bill Burmeister | | |
