7 members (TUTS 59, classicfins, KEVINSKI, MaxStewart, HandyAndy, Otto Skorzeny, 1 invisible),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,584 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 42 New Guy | | New Guy Joined: Oct 2010 Posts: 42 | Newbie here. Tearing down my '57 235 for rebuild. Any tips on removing the crankcase ventilation tube? If I understand it correctly its held in by friction but I can't get the thing to budge at all. Other than this everything else has come off the engine with ease. Any tips/advice are appreciated. Thanks. Newbie 1950 Chevy 3100 | | | | | Joined: Jan 2010 Posts: 32 New Guy | | New Guy Joined: Jan 2010 Posts: 32 | My experience was with a 56 GMC with pontiac v/8 316 ci. Early on like 56-57 we found the draft tube was pulling out oil. Like 3 qts in 180 miles. At least that is what we were told by mechanic in GMC dealership. So he pulled the draft tube up a bit and seemed to solve the problem. He also placed a bracket on the tube to prevent it from going down in to valley cover. It does fit snugly into valley cover. good luck! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Use a rubber hammer and tap it from side to side. Mine took some work but when it went back in, it wouldn't stay tight. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | when i was converting the draft tube to the breather/oil fill pipe on my 40-228 i was able to get the pipe to move left to right with the mallet but it wouldnt come out. i then took my porta power from the floor to where the two pipes are welded together on the draft tube and pushed it up until i heard the springs relaxing and tapped it back and forth some more then it finally came out. sometimes gravity is a wonderful thing. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Currently trying to remove mine as well. Same issue. Stuck. Tapped with a mallet, no luck. Have been resisting the urge to pull out the channel locks and try to get some twist on it. Or perhaps a combination of a strap wrench and a little mallet tapping will get it loose. My intention is to go ahead and install a PCV as mentioned on the forum. Just easier to change and will help with the oily film/stink that can come from the road draft tube. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey guys, I've never seen one that wouldn't come out by tapping back and foth with a rubber hammer on the center while keeping up pressure on the down tube. It's in fairly deep (bout a 1/2") so you might have to repeat this a hundred times or what ever it takes. You only move it a few thousands with each tap when you first start but eventually it will reach the top and pop out. Patiences is the key.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I think tapping and wiggling is the only way. Any thing like a pipe wrench or water pump pliers will only crush it. | | | | | Joined: Sep 2009 Posts: 35 New Guy | | New Guy Joined: Sep 2009 Posts: 35 | Did you all remove the bolt holding the bottom of the tube to the block ? | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I wonder if you can rig up some kind of expansion plug into the tube and then use a slide hammer.....just an idea. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I banged mine back and forth with a short piece of 2x4 and it wiggled back and forth. The 2x4 would be softer than a hammer but harder than a rubber mallet if that didn't work. I don't think a 2x4 can hurt it no matter how hard you hit it.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | So I managed to remove my tube this evening. Tapped lightly with a dead blow hammer from all directions. Then after no real movement I pulled out the large channel lock pliers. Mind you, these are big and have a max opening of around 4" I found a slipjoint that was just smaller than the tube, and with a light touch was able to twist back and forth until I got a little wiggle. Wiggled and wiggled and wiggled until it was moving freely. They i held the handle of the pliers with one hand, and twisted the tube left and right. I then pulled up with the other hand, and it came right out.
And you should have seen the sludge, er, gunk, um, nasty stuff that came from that part! I took pictures. It was completely closed up. So needless to say there was no ventilation taking place from the crankcase. | | | | | Joined: Oct 2010 Posts: 42 New Guy | | New Guy Joined: Oct 2010 Posts: 42 | UPDATE: slow and steady with a rubber mallet (and what felt like a hundred strikes) and it finally loosened up and came out. Thanks for all the advice, this site is great for a newbie! Newbie 1950 Chevy 3100 | | |
