7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74233 03/04/2007 7:21 AM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | I just spent the most frustrating day ever trying to put the transmission in my '53 3/4 ton. Started off with the clutch and it went in with no problem. Used an alignment tool and everything lined up dead center. Then came the problem. I used a transmission jack to raise the tranny and tried to get the damned thing to mate. No dice. So after about 7 hours, I gave up and went down and rented a cherry picker to try putting it through the floor like the manual says. Before doing that, I checked the alignment on the clutch and centered it again. It was off just a little, but hardly noticeable. Scratched hell out of my new painted dash using the cherry picker, but I managed to get the transmission back on the guide pins again. I am witin about 3/4" of the mating surface and can even put the lower bolts through from the back, but it will go no further and the U Joint is locked up tight. Maybe it is supposed to be locked up. I don't know. I don't know whether to start cinching down the lower bolts and hope that it will pull it in without damaging the clutch disk or what. I noticed the flywheel is harder to turn now than it was before, but I don't know if the front spline is through the clutch disk or if it is binding and causing that. I have it in 4th gear which is what the manual calls for. The clutch fork moves freely and is properly mated with the new throwout bearing. I guess I'm trying to figure out if it should go all the way forward to the mating surface on its own or if I'm binding up somewhere. I'd like to finish this tomorrow. Any suggestions out there? thanks. | | |
#74234 03/04/2007 7:54 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Rick, it sounds to me like it's not entering the pilot bearing, try backing off the tension a bit and use the throwout arm to release the tension on the disc, hope that helps. | | |
#74235 03/04/2007 9:03 AM | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | Rick
What new parts have you fitted ? Did they fit the trans input shaft prior to assembly ? ( pilot brg, clutch plate etc ) | | |
#74236 03/04/2007 3:45 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Rick; when I put the new clutch in my '49 GMC half, I also installed a new pilot bushing (not bearing). When I went to mate up the tranny, it was a very tight fit to get the input shaft into the bushing. Did finally go. | | |
#74237 03/04/2007 4:01 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Don,t force it. Hook up the clutch linkage & like 3b says release `the clutch. These alighnment tools are not allways acurate. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#74238 03/04/2007 5:39 PM | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Sounds like you need to disassemble everything and chack to see if all the parts are correct. Sometimes if the pilot bushing was pounded in with maybe a socket it maybe mushroomed out. | | |
#74239 03/04/2007 6:10 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Check to be sure all the parts fit separately before assembly, like the pilot bushing to input shaft, and clutch disk to input shaft. Be sure you have the clutch disk installed the right way. Do not use the bolts to pull the transmission home. It must slide in by hand or something is wrong. | | |
#74240 03/04/2007 6:40 PM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | i had same problem - i had a porta power jack - i placed it against the generator to the throwout fork - put just a little pressure to release the clutch a little & she popped right in . | | |
#74241 03/04/2007 6:41 PM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | should say generator bracket ( & do not force anything , or you could damage something ) | | |
#74242 03/04/2007 6:59 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Mine seemed a little bit stubborn on my 1 Ton. I had to use some force with my feet, lying on the floor. The technique worked and I remembered it from many years ago. | | |
#74243 03/04/2007 8:12 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | i agree with grigg,,check to see if clutch disk is right way, if in backwards tranny won't go on unless forced.... | | |
#74244 03/04/2007 9:25 PM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Well guys, before I pulled it all out and started over, I had someone push in on the clutch after I hooked up the linkage. It slid right in! Thanks to all of you for the input. Makes this site the best ever for stovebolters. Maybe this will save others countless hours of work and frsutration. Again, many thanks! Rick | | |
#74245 03/04/2007 9:35 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Rick, I'm glad it worked out for you, they can be frustrating little buggers. | | |
#74246 03/05/2007 1:50 AM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | | | |
#74247 03/07/2007 2:51 AM | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | I always use a pilot shaft from an old transmission to aline my clutch.I also use it to install the pilot bushing.I don't trust those store bought thingamagigs. ------------------ Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
