| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | Today I got differential/torque tube mounted back on the rear axle. All went well with minor cursing until I realized one of the lower bolt's threds was stripped/smashed - it must have happend during removal with the weight of the pumpkin sitting on it. No matter how hard I tried I cannot get the nut on. Can the bolts be removed? I was going to try to hammer it back into the axle housing to remove it to use a die on the the threads. But before I make it worse I thought I'd ask here. (Of course none of the vendors have any listed in their catalog). Thanks! | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | If there is enough room you should be able to put a die nut on it and chase the threads right in place. If you are lucky some mechanic friend might have one and you won't have to buy a complete set. They are made to work with a regular socket and work great for what you are trying to do. I just googled die nut, it gives a pretty good description of it so you will know what to look for. Dave
1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | Homer 52: Thank you, Thank you!! I didn't know there was such a thing. I was thinking of a something like a 3" long die and knew that wouldn't fit. I'm searching for a die nut on ebay now. Just happy I won't have to try to remove the bolt. Thanks again. Dave | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Talk to a Snap On dealer. They have them. | | |
