3 members (Shaffer's1950, walter74, tclederman), 121 guests, and 3 robots.
Topics128,129
Posts1,056,700
Members48,454
Been looking for that thread where there was a discussion on how to disconnect the diaphragm from the link on an AC fuel pump rebuild. Anyone remember that????
Denny Graham
Sandwihc, L
Denny G
Sandwich, IL
Last time I had one a part was a while ago, but don't remember any troubles or confusion, or needing any help?
Do you have a picture of the issue?
•1952 Chevrolet 3800 pickup
---All pictures---
I think I used a punch and took the pin out of the main body that holds the pump arm in place. Then I think I was able to disconnect it from the diaphragm. Don
It was simple Grig, just wasn't sure how the stem was atteched to the link. I hadn't really taken a good lool at it, I was just preping for it. All you have to do is hold the arm while pushing down on the diaphragm and kick the stem back out of the link. Simple!!!!
Now, I have to finger out the inlet and out let seals or valves. I gotta get a kit to see just what new parts comes in it before I try to pop them out. Don't know if I'll have to use the old retainers or not.
No need to pop the pin out or remove the arm Don.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Just incase anyone else may be interested.
The diaphragm link:
http://www.pbase.com/dennygraham/image/130835675/large
The diaphragm stem:
http://www.pbase.com/dennygraham/image/130835677/large
The reason why:
http://www.pbase.com/dennygraham/image/130835756/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny, when I did mine I was concerned about tearing the diaphragm. I was looking at a spare in the parts box and agree removing the pin can be avoided. I guess another point would be how much grime is in the arm area of the housing for cleaning purposes. Its like many things, many different roads to the destination and everyone likes to look at different scenery. Thanks for all the great info. Don
I'm in the process of rebuilding the fuel pump for my 1941 Chevy, and was having some troubling removing the diaphragm from the link. Pushing down on the diaphragm and away from the rocker arm side of the pump, without allowing it to swing or pivot did the trick.
