7 members (Phak1, 78buckshot, Oldcaliforniakid, BC59, Wally / Montana, MickeyP, Gdads51), 85 guests, and 2 robots.
Topics128,049
Posts1,055,667
#742033 04/24/2011 4:49 AM
i have a simple question. i was thinking of using an alternator in place of the generator. the motor is a 235. my reason for thinking this is....
1. i would like to put better headlights, taillights, etc.
2. i want to add a radio and a couple of small speakers
3. i want to be able to have a hidden power outlet for charging a cell phone or running a spotlight or other small electrical devices
Good or bad idea?
Keeper' between the mustard and the mayonnaise!!
Keep in touch!!
ratrodstovebolt
http://s1183.photobucket.com/albums/x480/ratrodstovebolt/
There's nothing wrong with using an alternator, and you can fit one with up to 100 amps or so capacity, as opposed to about a 45 amp max for the largest DC generators. The alternator will also charge at idle, something the generator doesn't do well.
That being said, none of the accessories you've described so far will draw more power than a good generator can produce. The late-1950's Oldsmobiles and Cadillacs used 45-amp generators with ball bearings on both ends, and supported far more original-equipment accessories than your tricked-out stovebolt would have.
is it much of a hassle to switch it to an alternator.
Keep in touch!!
ratrodstovebolt
For stock load the stock generator should do well.
HOWEVER you are talking about added load.
You therefore may need more generation whether generator or alternator is now the question.
Generators are more maintenance than alternator ASSUMING same quality
Alternators are a bit more tolerant of dirt and water ASSUMING slip rings.
IF brushless excitation then they are almost immune.
From my experience as an industrial electrician AC is generally the first choice over DC any day - there are exceptions but they dont apply to vehicles.
The next choice is 6 or 12 volt. That is made probably on personal preferance cost and availability (on a daily or 3 day basis) for replacement parts.
Dan Bentler
well its already 12 volt. my main reason of concern i wanted to address is, why do i get brighter lights at higher rpms and not at idle. my volt meter bounces a bit at idle but stays steady at higher rpms. is it common with generators or is there some other type of issue i should be addressing? i just assumed that with a generator, if it was bouncing at idle with just factory electronics, then generator wouldnt hold up to added things such as a modern radio and lighting as well as an alternator.
Keep in touch!!
ratrodstovebolt
rat - you don't have any "factory electronics", and a modern radio probably takes less power than an original would - the reason the lights fade at idle is the generator isn't putting out enough or the regulator is maladjusted, that's not the original behavior, there's no reason a good original generator won't handle anything you want to put on the truck - you likely have a worn out generator, either take it to an auto electric shop and have it evaluated [best to have the regulator with it] and get it rebuilt or get a higher output one or go with an alternator, nothing to cause concern
well that clears that up. LOL!! thanx for the knowledge. i guess i, or should i say you, just saved me from doing something senseless. LOL!! your opinion, is it better to rebuild or replace?
Keep in touch!!
ratrodstovebolt
for a driver I'd go with what's cheaper, depends if the generator maybe just needs brushes and the regulator adjusted or if either needs replacing, which might be pricey - you can prolly find an alternator from a wrecker cheap, pretty easy to adapt with mount pieces off a later 6 cyl
ok. that helps out a lot. thanx again!!
Keep in touch!!
ratrodstovebolt
Riding in the Passing Lane
To me there are so many advantages to the alternator, the only reason to use a gen. is if you wanted to keep the original look or you are not really going to drive the truck.
1972 Chevy c10 Cheyenne Super
