10 members (DadsFirstPickup, 5 Window 9434, TrknGMC, Guitplayer, 3800GUY, Woodcmiami, KCMongo, Shade Baby, 2-Ton, 1 invisible),
121
Mod | | | Forums66 Topics128,049 Posts1,055,662 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | i have a simple question. i was thinking of using an alternator in place of the generator. the motor is a 235. my reason for thinking this is.... 1. i would like to put better headlights, taillights, etc. 2. i want to add a radio and a couple of small speakers 3. i want to be able to have a hidden power outlet for charging a cell phone or running a spotlight or other small electrical devices
Good or bad idea? | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | There's nothing wrong with using an alternator, and you can fit one with up to 100 amps or so capacity, as opposed to about a 45 amp max for the largest DC generators. The alternator will also charge at idle, something the generator doesn't do well.
That being said, none of the accessories you've described so far will draw more power than a good generator can produce. The late-1950's Oldsmobiles and Cadillacs used 45-amp generators with ball bearings on both ends, and supported far more original-equipment accessories than your tricked-out stovebolt would have. Jerry
| | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | is it much of a hassle to switch it to an alternator. | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | For stock load the stock generator should do well.
HOWEVER you are talking about added load. You therefore may need more generation whether generator or alternator is now the question.
Generators are more maintenance than alternator ASSUMING same quality
Alternators are a bit more tolerant of dirt and water ASSUMING slip rings. IF brushless excitation then they are almost immune.
From my experience as an industrial electrician AC is generally the first choice over DC any day - there are exceptions but they dont apply to vehicles.
The next choice is 6 or 12 volt. That is made probably on personal preferance cost and availability (on a daily or 3 day basis) for replacement parts.
Dan Bentler | | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | well its already 12 volt. my main reason of concern i wanted to address is, why do i get brighter lights at higher rpms and not at idle. my volt meter bounces a bit at idle but stays steady at higher rpms. is it common with generators or is there some other type of issue i should be addressing? i just assumed that with a generator, if it was bouncing at idle with just factory electronics, then generator wouldnt hold up to added things such as a modern radio and lighting as well as an alternator. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | rat - you don't have any "factory electronics", and a modern radio probably takes less power than an original would - the reason the lights fade at idle is the generator isn't putting out enough or the regulator is maladjusted, that's not the original behavior, there's no reason a good original generator won't handle anything you want to put on the truck - you likely have a worn out generator, either take it to an auto electric shop and have it evaluated [best to have the regulator with it] and get it rebuilt or get a higher output one or go with an alternator, nothing to cause concern
Bill | | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | well that clears that up. LOL!! thanx for the knowledge. i guess i, or should i say you, just saved me from doing something senseless. LOL!! your opinion, is it better to rebuild or replace? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | for a driver I'd go with what's cheaper, depends if the generator maybe just needs brushes and the regulator adjusted or if either needs replacing, which might be pricey - you can prolly find an alternator from a wrecker cheap, pretty easy to adapt with mount pieces off a later 6 cyl
Bill | | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | ok. that helps out a lot. thanx again!! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | To me there are so many advantages to the alternator, the only reason to use a gen. is if you wanted to keep the original look or you are not really going to drive the truck. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
