2 members (baldeagle, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#741943 04/23/2011 10:20 PM
Found the brake fluid reservoir for my 49 Thriftmaster under the floor board. Having a difficult time getting the top off. Isn't that suppose to screw off when the bolt is loosen or am I missing something? Won't move. Soaking it in W-D.
What seems so easy just never is.........
Be careful spraying the WD-40 on the master cylinder cap. There is a vent hole on the cap. If the WD gets into the master cylinder it will contaminate the brake fluid and you'll need to flush the system. The original caps have a square top metal cap that you can get a open end wrench on from under the truck. If you have a replacement master ,the cap may be plastic with two wings on the cap that will loosen with pliers. The plastic caps never freeze onto the master. You must have the steel cap. Have patience, you're dealing with an old truck, and they can be stubborn.
This is all metal. Was unaware of the vent hole. Don't even see one.
Hopefully I did not make the problem worse.
Will keep tugging at it.
Many thanks.
Another way tp get it off is to use a square or 8 point socket with an extension. It should be 3/4", same as the plug on the rear differential cover.
Bill Burmeister
