1 members (klhansen),
149
Mod | | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 22 New Guy | | New Guy Joined: Oct 2008 Posts: 22 | Found the brake fluid reservoir for my 49 Thriftmaster under the floor board. Having a difficult time getting the top off. Isn't that suppose to screw off when the bolt is loosen or am I missing something? Won't move. Soaking it in W-D.
What seems so easy just never is.........
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Be careful spraying the WD-40 on the master cylinder cap. There is a vent hole on the cap. If the WD gets into the master cylinder it will contaminate the brake fluid and you'll need to flush the system. The original caps have a square top metal cap that you can get a open end wrench on from under the truck. If you have a replacement master ,the cap may be plastic with two wings on the cap that will loosen with pliers. The plastic caps never freeze onto the master. You must have the steel cap. Have patience, you're dealing with an old truck, and they can be stubborn. | | | | | Joined: Oct 2008 Posts: 22 New Guy | | New Guy Joined: Oct 2008 Posts: 22 | This is all metal. Was unaware of the vent hole. Don't even see one.
Hopefully I did not make the problem worse. Will keep tugging at it.
Many thanks. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Another way tp get it off is to use a square or 8 point socket with an extension. It should be 3/4", same as the plug on the rear differential cover.
Bill Burmeister | | |
