2 members (Southerntruck, Hush), 150 guests, and 2 robots.
Topics128,114
Posts1,056,287
Members48,439
On my '68 C-20, I aminstalling the 'pumpkin' on an Eaton-Type axle. Does that side of the differential get a gasket? I cannot tell from the looks of the old surfaces.
Thanks...
57 3/4 ton rat
66 C-10 panel 350 200R4 3.07 axle
68 C-20 dump runner, 250 4spd, 4.11
82 Camaro, 305, THM-200-R4
84 Monte Carlo, 350, TH350
EVERETT, WA
Yes!
But you can make one or just use High-temp RTV, like Perma-tex Orange. Clean surfaces well and just lightly skin it on; then assemble and torque to specs. smile
*** GMC ***
WHat he said cool
Thanks, guys, going with ultra black on the carrier, and the 1 gasket I could get on the cover.
57 3/4 ton rat
EVERETT, WA
