3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#741552 04/22/2011 1:53 PM
BC1
Offline
Hi guys; can anyone tell me what this vin translates to. It appears to be odd from what I can find on line. It's on the title of a 1955 chev half ton pu 1st series that I just bought. The truck was restored in the 80's and the door pillar plate was removed to paint a new color.
0235073F55X Thanks!
BC1 #741565 04/22/2011 2:34 PM
that's the engine number, which is mostly what was used back then to register a vehicle .... if it doesn't still have that original engine installed you have some work to do with titling to prove the title really belongs to the truck
squeeze #741688 04/22/2011 11:33 PM
Z
Z Offline
BC1,my advice,would be you need to check with your local BMV,and see what they would need to clear that situation.Just remember all states are different,mostly a matter of making it legal. I am in the same situation,with my vehicle,the reason I am commenting.If you work with the Title people,at your local BMV,they have been real helpful,for me,just time consuming.Good Luck.
squeeze #741718 04/23/2011 1:09 AM
Agreed. The number is correct for a '55 1rst 1/2 ton.
Bill Burmeister
