| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Anyone notice that the 1941-1946 chevy shop manual has no instructions for removing the engine for the truck??? Gotta be simple enough though. Should I remove the 4 bolts from the bellhousing to transmission, and all three motor mounts and pull it that way or do I pull it WITH the transmission still attached as well? Thanks
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Support the trans. & leave it in. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Ok. Thanks! That is the route I started to take...all was going well except the rear engine supports are a bear! The bolt through the cross member just spins and the two that screw into the bellhousing are nearly impossible to remove from what I can tell so far (the top bolt was easy, the bottom buried in dirt and grease and the bolt to frame nut is in the way). Any suggestions?
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | On our 46 the trans was supported by the frame cross member , with no front sheet metal on, the engine came out slick. This is a 3/4 ton so perhaps the frame is different. | | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Ok, got the engine out! After digging out lots of dirt and grease from around the lower bolts, it was obvious to just take out the cross member bolt and remove the engine with the mounts attached. Was finally able to get a socket on the top of the bolt from inside the cab and use another socket from under to get them out. Should have drained tranny before removing two lower bellhousing bolts though as they became an escape for the fluid. Ooops!
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | BTW, is it normal for the tranny fluid to empty out both lower bolts that connect tranny to bellhousing? My neighbor thought it was not.
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I don't see how that can happen, the mounting pads do not go into the transmission, at least they don't on my 41 3-speed. Just thought about it again, could you have disturbed the countershaft while loosening it from the bellhousing and the leak was from the counter shaft? Dave
1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | The bottom right bolt hole on my 41 four speed does apear to go all the way thru just below the reverse idler shaft. This would leak fluid when the bolt is removed as the oil level when full is about 1" above that hole. | | |
