4 members (klhansen, baldeagle, Simon1954, pkr), 63 guests, and 10 robots.
Topics128,019
Posts1,055,343
Members48,419
#741146 04/21/2011 3:24 AM
I am trying to use a 292/sm420 and a 1 ton rear end for a power unit to run a piece of machinery. If I lock on side of the differential down, how fast will the free hub turn? Twice as fast as normal? or the same speed as the drive shaft? I have been told both.
Glen E.
1 Offline
Twice the speed of the drive shaft if one side is locked . If this is incorrect, we just discovered a whole lot of NEW FREE energy!
Thanks, I think the rear end should make a good right angle drive, but if its double the drive shaft speed I will have to do some rear-gearing on my chain drive sprockets. I guess I can jack up one side of my pickup and spin the drive shaft and count the revolutions for shaft and wheel.
Glen E.
I'm not sure about the differential ratio. But you can always lock the differential gears, then be at the correct ring and pinion reduction.
It will turn neither twice the speed of normal nor the speed of the driveshaft. It will turn at it's usual speed.
