1 members (baldeagle),
37
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 21 New Guy | | New Guy Joined: Apr 2004 Posts: 21 | I am trying to use a 292/sm420 and a 1 ton rear end for a power unit to run a piece of machinery. If I lock on side of the differential down, how fast will the free hub turn? Twice as fast as normal? or the same speed as the drive shaft? I have been told both.
Glen E.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Twice the speed of the drive shaft if one side is locked . If this is incorrect, we just discovered a whole lot of NEW FREE energy! Jerry
| | | | | Joined: Apr 2004 Posts: 21 New Guy | | New Guy Joined: Apr 2004 Posts: 21 | Thanks, I think the rear end should make a good right angle drive, but if its double the drive shaft speed I will have to do some rear-gearing on my chain drive sprockets. I guess I can jack up one side of my pickup and spin the drive shaft and count the revolutions for shaft and wheel.
Glen E.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I'm not sure about the differential ratio. But you can always lock the differential gears, then be at the correct ring and pinion reduction.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It will turn neither twice the speed of normal nor the speed of the driveshaft. It will turn at it's usual speed. | | |
