1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
What is the difference between a thriftmaster 235 and a loadmaster 235?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
What year?
In 1954/55st: different piston rings and different valve-train parts (valve composition, valve-rotator spring-caps, lash-settings). Probably a different valve-cover decal.
yes i was reffering to the 1954 235. interesting thanks!
The ThriftMaster name was used on the pickups and the LoadMaster name was used on the larger trucks. There were some internal and external differences.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Look here.
I hope this is useful.
Professional Novice
Some additional information is in the 1954 RestoPack. The Loadmaster, with the valve rotators and other mods that Tim mentioned, came in the larger trucks.
Hoyt
The first year for a Thriftmaster and Loadmaster 235 was 1954.
In later years, there were also Thriftmaster & Loadmaster 235s but I do not know how long this continued. There was also the Jobmaster 261 and later the Taskmaster V-8s.
there was only one 235 version after 55.2, the Thriftmaster - in 56 the Loadmaster became a 322 V8, there was 2 versions of the 265: Trademaster and Taskmaster - names changed again in 57 after the 265 was dropped and the 322 was swapped for the 348 .... what's in a name? advertising grin
cool thanks for all the neat info!
