| | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | Hi All I see there is a reproduction 292 ci exuast manifold for a chevy but there is no hole for the two speed vacum any ideas?
Home » Engine » Manifold » Chevy 292 Manifold Categories Other Sections
292EM 292EM Chevy 292 Manifold $159.44
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy crockbuyer, I don't really understand your post, the vacuum to operate things like vacuum wipers, or two speed vacuum shifted rear axles comes from the intake manifold, not the exhaust manifold. The 292 engine is a truck only engine and an intake manifold for it should have port[s] in it to connect vacuum accesories to, hope that helps. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I'm kinda confused by the whole post myself. 3B, your answer is a true statement, but I'm not sure what he's actually asking. | | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | Thanks for the info. Here is what I mean There is a reproduction 292 intake exuast manifold for sale. But the is no hole in the intake for the vacum line to bolt into and was wanting to know if the was a fix to use the new reproduction one. Because finding a used one is impossible Thanks tony | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Can you drill and tap what you need? | | |
