| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | What is the difference between a thriftmaster 235 and a loadmaster 235? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year?
In 1954/55st: different piston rings and different valve-train parts (valve composition, valve-rotator spring-caps, lash-settings). Probably a different valve-cover decal.
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | yes i was reffering to the 1954 235. interesting thanks! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The ThriftMaster name was used on the pickups and the LoadMaster name was used on the larger trucks. There were some internal and external differences. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Look here. I hope this is useful.
Professional Novice
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Some additional information is in the 1954 RestoPack. The Loadmaster, with the valve rotators and other mods that Tim mentioned, came in the larger trucks. Hoyt | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The first year for a Thriftmaster and Loadmaster 235 was 1954.
In later years, there were also Thriftmaster & Loadmaster 235s but I do not know how long this continued. There was also the Jobmaster 261 and later the Taskmaster V-8s.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there was only one 235 version after 55.2, the Thriftmaster - in 56 the Loadmaster became a 322 V8, there was 2 versions of the 265: Trademaster and Taskmaster - names changed again in 57 after the 265 was dropped and the 322 was swapped for the 348 .... what's in a name? advertising  Bill | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | cool thanks for all the neat info! | | |
