| | | Forums66 Topics128,083 Posts1,056,332 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74071 03/01/2007 5:28 AM | Joined: Feb 2007 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 14 | Ive been having the hardest time with the brakes on my truck. I replaced all the wheel cylinders on it and the MC, but is hasnt fixed the problem. I've put thousands of miles on it the way it is, but it is WAY too dangerous. I have to pump the brakes a good 3-5 times before i get pedal pressure. It has brake fluid in it, and I've tried bleeding them also. I pulled off the passenger side brake drum and the shoes look like they have plenty of meat on them. i had them adjusted once and they were good for about 1000 miles, but were gradually getting worse that whole time. If anyone has any idea of what this problem could be I'd love to hear it. Thanks, Ken | | |
#74072 03/01/2007 6:24 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | These are tricky to adjust. There are 2 adjustments on each wheel. All the adjustments are right hand threads so the adjuster spoon goes in opposite directions. Tighten each adjuster till the wheel gets hard 2 turn & back it off 2-4 notches. When these are right there is practically no movement in the brake poedal. You just apply pressure. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#74073 03/01/2007 6:49 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Yup! And you may have to bleed them after your done, you might have sucked some air into the lines. | | |
#74074 03/01/2007 6:54 AM | Joined: Feb 2007 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 14 | alright im going to give adusting them a shot next weekend. does it sound right for them to need adjusting just after 1000 miles? how often should i have to adjust them? thanks for the advice | | |
#74075 03/01/2007 2:37 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes it's normal to need adjusting at first. You have worn down the high spots & the linings are seated. After that probably 3-4 thousand miles. I still question wheather they were adjusted right the first time. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#74076 03/01/2007 6:47 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by Wrenchbender Ret.: Yes it's normal to need adjusting at first. You have worn down the high spots & the linings are seated. After that probably 3-4 thousand miles. I still question wheather they were adjusted right the first time. It doesn't sound like it. That's what mine were doing until you smacked me up side the back of the head.  | | |
#74077 03/02/2007 9:54 PM | Joined: Feb 2007 Posts: 1 New Guy | | New Guy Joined: Feb 2007 Posts: 1 | Ken i was having simliar problems with the brakes on my 52, i had replaced the wheel cyl. and master cylinder, adjusted brakes cyl. and bled them many times. but always had to pump brakes alot and still the brake peddle would fade down to the floor board. i read about speed bleeders here on the bolt. i installed them all around, no more problems. i paid 21 with tax for 4 of them at autozone. best $21 i've spent on my truck thus far. (take an old bleeder with you when you go, because they have many of different sizes)
dillinger
