2 members (VicZ, klhansen), 118 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
#740759 04/20/2011 12:12 AM
I have a 1990 2500 Chev. This my modern truck. The trans has started to whine as I accellerate so I expect something is wrong. This is a non overdrive trans. So my question is: Will a newer trans with overdrive just bolt in?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Your 90 has basically a TH400. GM upgraded in 91 to the 4L80E (overdrive) which is electronic computer controlled. Perhaps someone offers a kit for the conversion. You might try Bowtie Overdrives. The 1500 series trucks used a 700R4 overdrive whch may also work with some possible differences in the tailshaft length, yoke, and u-joint.
Fred
Well Mike, don't accelerate, then it won't whine. Maybe an SM420 would work well in there. With a little help from a drill, hot wrench, some off-set special application bolts, I'm sure you can make it work. I'm sure one of your "old truck" friends would help you. I'm not too busy right now.
Bill garvey
Thanks Fred, that sounds like more than I want to do to this truck, but I will check it out and see.
Bill, I still need to accelerate, so, I studied it a little and found that if I turn the radio way up loud, I don't hear it anymore. Problem solved!!
1946 1-ton Panel
