2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 30 New Guy | | New Guy Joined: Apr 2011 Posts: 30 | Hi guys/gals, i'm an independent insurance appraiser from Central Florida. I need a little help an a serial number. The truck I'm dealing with has a number that starts 2NLxxxxxx. I know the 2 is for Tarrytown, NY. I've looked on every site I know of and nothing shows an 'NL' for either car or truck. Can anyone shed some light on 'NL'?
Thanks!
Another Day In Paradise...
1964 Studebaker Daytona 1964 Studebaker Commander
| | | | | Joined: Apr 2011 Posts: 30 New Guy | | New Guy Joined: Apr 2011 Posts: 30 | Um, any confirmation the 'NL' is a made up pair of letters?
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | whats the truck- that might help us out- at least the year. Is it the VIN or is it the engine number? If the number you have is off of a title or reg. and pre 55, it might be an engine number. | | | | | Joined: Apr 2011 Posts: 30 New Guy | | New Guy Joined: Apr 2011 Posts: 30 | It's supposed to be a 1942 1/2 ton. The guy found a cab without the serial number plate on it. I know the engine numbers are far different (usually starting AAKxxxxxx or similar). The engine in the truck is a 502.
The number sequence is similar to GM, but I've still seen nothing in the GM manuals that show anything begining with an '2NL'. Thoughts?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 502 in a 1/2 ton? Sounds like the truck is pieced together. | | | | | Joined: Apr 2011 Posts: 30 New Guy | | New Guy Joined: Apr 2011 Posts: 30 | Oh, yeah. And I'm thinking the serial number is the same way.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | so ... what was the question? where does the number come into it? from the title? why would the number on a title relate to a collection of parts?
Bill | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | if it was a gmc i could help you out. since its a chevy i know less than you do. | | | | | Joined: Apr 2011 Posts: 30 New Guy | | New Guy Joined: Apr 2011 Posts: 30 | This collection of parts actually rolls on an S-10 chassis. It's cobbled together. I need to verify the Serial Number matches the vehicle. I might be willing to say that cab may have gone done the Tarrytown Assembly Plant. But what year? Was this a 1/2 ton? Was it a CEO (no)? Was it from a 2 ton truck?
From all the GM stuff I see so far, 'NL' means...nothing. There wasn't an 'NL'. It this is the case, this guy needs to get the vehicle titled correctly.
Why does this make a difference? If totaled, the insurance company now buys the salvage. Then THEY are responsible when someone who knows these trucks says, "Hey! There was no 'NL' truck!" If I can't show that 'NL' means something and the vehicle isn't a total, they'll drop him because the vehicle is a ...fraud.
| | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | where is the truck? you know the issue i was having with mine from contact on tjj. I have found the forms to get georgia to issue a new serial # for my 41. could it be the same type of deal? | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | if you go to......brads41-46chevys.com.. they have a serial number decoder on that site, on the left column, scroll down, you'll see it there | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Swifster Sure wish people would use real names in their post. It is nice to know whom you are corresponding with. To your problem. I suggest you come up with a valid engine #. Sounds like the # you are asking about does not exist. Once you get a # take it to your State Motor Vehicle Registration Office & apply for a corrected Title (if you live in a title state). If not a title state you will probably need a Bill of Sale with the motor # listed. Trucks did not have VIN numbers until sometime in the 1950's. The Tag on the cab was a unit ID #. Hope this helps. Harold
Harold Is a restoration ever finished? | | |
