1 members (baldeagle),
38
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I'm close to painting my truck. I'm leaning to a two part system (base & clear). However, I was watching one of those truck shows and they used DupliColor paint for painting a deuce-and-a-half. No mixing or additives were required. It was relatively inexpensive to paint such a large vehicle. Has anyone had experience with this paint? | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have noticed this paint is available at Autozone. I would like to read about anyones experience or advice.
I didn't think it was that inexpensive at $22.95 a quart. Maybe, I am wrong. And I was disappointed that they did not have grey. I want to paint my interior grey.
Thanks to all
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | Not many colors to pick from unless you start mixing it yourself which negates the whole ready to go part. If you decide to go for it, let us know how it goes. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I thought this would be a good system for us 'novelists.' The Duplicolor system I looked at in Autozone has a 3 system setup. They sell the primer, paint, and clear coat. I thought it was nice not to fear mix and match products.
I'm just not sure if painting in my driveway is good.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | OBT - compare 22.95/qt to most high end auto paints at 50.00 or more .... the gray (metallic) would be a good interior color .... if you don't want overspray on the property, use a brush and roller, worked great for daBus  Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Great. Thanks for the information.
I cannot figure out how far a quart goes? Would a quart do one coat of the bed? Or the cab? Or the cab and front? Or half the truck?
I have a cannister sprayer. So, how much do you put in the can for spraying. I would probably do the interior - so how much for a single layer? Then wait for time to pass and do another? Two coats?
Maybe it would be worth it to buy a quart of the primer and see how far that goes. Would that be a good way to guess-ti-mate how far it goes? And a good way to practice spray technique
