1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | I am trying to get the dome lamp working. Got it wired and have a new headlight switch. Got the wiring diagram too... The light will NOT shut off!! Been down this road before. Any help?
Thanks in advance,
Steve in I-DA-HO | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It means the circuit isn't opening to shut it off. It would have to be either a bad switch or something not connected right. Do you have a multimeter?
| | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | My ultimate question is HOW to wire at the lamp itself. I have missed something at the lamp for sure...this is killing me cause I am sure it is way easy. thanks in advance
Steve | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the orange wire from "D" on the switch to the lamp is hot all the time the white wire from "GRD" on the switch gives it a ground when turning the knob [the one click direction]
if it's on all the time, you have a ground on the light body that doesn't belong there - remove the white wire from the switch, if the light is still on you have the lamp grounded [which it should not be], if it goes out you have the switch in the on position, or it's wired wrong, or it's defective
Bill | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | I have a two pole pig tail in the lamp assembly which I would assume is the correct one...right? All I did was connect the two wires to the tow wires from the lamp switch. Am I doing something wrong? Thanks, Steve | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you hooked the same colors together that should be good, so then you need to check to see if the way the light is mounted adds a ground to the socket where there shouldn't be one .... and check if the switch is doing it's job right, does it 'click' when you turn it one way and dim the dash lights when turned the other way?
Bill | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Hey Bill,
The switch is working fine...dimmer works and it does snap when turning to the left for dome lamp. Does the seitch need to be mounted for ground? I have it hanging. I'll go try that right now to see. Everything seems to be wired fine...I think. I replaced the wires cause there were NONE when I got the truck. So, they are NOT the original color. Gonns go check. By the way,,,I solved the last problem...was the dist cap retaining screw not all the way to the right...it was moving ever so slightly but causing a major loss of power while driving. Thanks again...I'll get back to ya in a few with the results.
Thanks, Steve | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes the switch needs to be grounded [normally by mounting], but if the light is on all the time that means it's getting a ground when it shouldn't - if you have a meter, disconnect the wire from the GRD terminal on the switch - if the light stays on you might have nicked that wire when fishing it up to the light and it's shorted to ground along the way - use the ohmmeter to track down the unwanted ground
Bill | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Got it Bill...I insulated the lamp assembly to resolve the extra grounding problem. Works great now and hope it's like the energizer bunny and keeps working!! Pretty sure it's just another OLD truck thing that needed to be bypassed...thanks again
I can wire the truck but when it comes to that darn dome lamp I wanna yank the rest of my nubs out..lol
Steve in I-DA-HO | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | By the way...I am not fishing any more wires up to that darn lamp!! Already got the headliner glued up and the NEW hard to install rubber retainer installed...that was a PAIN in the keester!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 |  I can relate! just drive'er and smile I seem to recall now that light assembly had a cardboard plate it mounted on, hadn't thought about that  Bill | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | yep...I got some o-rings and drilled the mounting holes in the lamp assy so the screws and the plate wouldn't touch the cab and waalaa!! All good now!! | | |
