2 members (baldeagle, homer52),
36
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | Apache 3100 Looking for ideas for removing orginal undercoat, nothing seems to cut it. Thanks Larry
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Camsore, not sure what you mean by 'original' undercoat? Is the whole underside treated?
My '50 had very little from what I could see,is it possible a previous owner has done it?
What little there was on mine scraped off with a single edge razor blade, it was baked solid by the So-Cal sun. It actually came off in flakes. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Heat gun to soften it then a scraper to remove it. Don't use an open flame.
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I used WD-40 spray it on and let it set then scrape it off. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | I use a Multi Function tool from Harbor Freight. It is a sonic vibrator and the knife blade takes off undercoating easily. It has many adapters, saws, sanders,etc. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | John’s method of carefully chipping off the loose stuff and Don’s WD-40 is what I’ve used on my ’50 firewall. The undercoat was a way up on the lower part of the firewall. http://www.pbase.com/dennygraham/image/116749957 WD-40 is mostly just kerosene so that will work just as well and it’s cheaper. You’ll use up a lot of rags but you won’t scratch up the paint if its good under the coating. DG
Denny G Sandwich, IL
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | For a good scraper that won't hurt paint etc. the harbor freight plastic scrapers are nice, I use them for lots of things, like removing old windshield rubber etc. Plastic is the best way to go if you don't want to damage stuff. Hot pressure wash and steam cleaning takes it off too, if I remember, long time sice doing that.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
