1 members (Hotrod Lincoln),
105
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | where can i find a diagram of the eaton 4:10 from 67-72? and an HO50 for a 53 3600 would like to have something to look at before i take them apart
thanks rolf
1963 c10 | | | | | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | Get a dealer shop service manual for the particular year truck that you want to know about. Only that will have the complete info. Aftermarket 'manuals' are way too condensed to be of much value IMO. Doug | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | There's one in this ad Not trying advertise here, I don't know how to remove it and post it here without the ad. You can also find it posted in the ebay/caigslist section under HO52/HO72 Differentials | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Rolf, the 67-72 Eaton is an HO52 rear axle, itt just that some of them during those years had a 4.10 ring and pinion instead of the 4.57 most were equiped with. The housing, cover, center sections will all look the same for all the years. All of the Eatons were HO52's. DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | all i found a rear axel at a junk yd in abilene that had the thw code on it turns out it was on a 1/2 ton and the carrier was not a bolt on like the one on my 53 i'm gonna go back and try to find one so now i have a 12 bolt rear end i don't need i do have a 9 in ford rear end off a 64 pu but the bolt pattern is different
i'm also still searching for a 3 spd od manual for he 53
rolf
1963 c10 | | |
