1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#739073 04/14/2011 6:40 AM
Apache 3100 Looking for ideas for removing orginal undercoat, nothing seems to cut it.
Thanks Larry
Camsore, not sure what you mean by 'original' undercoat?
Is the whole underside treated?
My '50 had very little from what I could see,is it possible a previous owner has done it?
What little there was on mine scraped off with a single edge razor blade, it was baked solid by the So-Cal sun.
It actually came off in flakes.
More pix on Flickr.
Ex Hall Monitor
Ex Hall Monitor
Heat gun to soften it then a scraper to remove it. Don't use an open flame.
I used WD-40 spray it on and let it set then scrape it off.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
I use a Multi Function tool from Harbor Freight. It is a sonic vibrator and the knife blade takes off undercoating easily. It has many adapters, saws, sanders,etc.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
John’s method of carefully chipping off the loose stuff and Don’s WD-40 is what I’ve used on my ’50 firewall. The undercoat was a way up on the lower part of the firewall. http://www.pbase.com/dennygraham/image/116749957
WD-40 is mostly just kerosene so that will work just as well and it’s cheaper. You’ll use up a lot of rags but you won’t scratch up the paint if its good under the coating.
DG
Denny G
Sandwich, IL
For a good scraper that won't hurt paint etc. the harbor freight plastic scrapers are nice, I use them for lots of things, like removing old windshield rubber etc. Plastic is the best way to go
if you don't want to damage stuff. Hot pressure wash and steam cleaning takes it off too, if I remember, long time sice doing that.
