3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#738748 04/13/2011 3:36 AM
where can i find a diagram of the eaton 4:10 from 67-72? and an HO50 for a 53 3600
would like to have something to look at before i take them apart
thanks
rolf
1963 c10
Get a dealer shop service manual for the particular year truck that you want to know about. Only that will have the complete info. Aftermarket 'manuals' are way too condensed to be of much value IMO.
Doug
There's one in this ad Not trying advertise here, I don't know how to remove it and post it here without the ad. You can also find it posted in the ebay/caigslist section under HO52/HO72 Differentials
Rolf, the 67-72 Eaton is an HO52 rear axle, itt just that some of them during those years had a 4.10 ring and pinion instead of the 4.57 most were equiped with.
The housing, cover, center sections will all look the same for all the years. All of the Eatons were HO52's.
DG
Denny G
Sandwich, IL
all
i found a rear axel at a junk yd in abilene that had the thw code on it
turns out it was on a 1/2 ton and the carrier was not a bolt on like the one on my 53
i'm gonna go back and try to find one
so now i have a 12 bolt rear end i don't need
i do have a 9 in ford rear end off a 64 pu but the bolt pattern is different
i'm also still searching for a 3 spd od manual for he 53
rolf
1963 c10
