Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Woodcmiami, tclederman, Otto Skorzeny), 145 guests, and 3 robots.
Topics128,282
Posts1,058,496
Members48,490
#734113 03/28/2011 11:44 PM
Does anyone know where to find the spring that attaches to the adjustment arm that allows the seat to slide forward or back? Or does anyone know the correct size/length so that I can get one at the local hardware store?
Must be a rare spring?
I'll be glad to measure mine for you this weekend, but it's a 58 and I think the seat styles may have changed when body styles changed in 55?
gobolt
gobolt #741112 04/21/2011 1:26 AM
Ya mean this one??? http://www.pbase.com/dennygraham/image/134088210/large
16"x 3/4"x.125"
DG
Denny G
Sandwich, IL
Mind if I steal this thread a minute? Denny, You or somebody posted the dimensions of the metal rod seen in that pic that attaches to the seat tracks at both ends. If it was you, would you mind posting it again? I have to make one. I should add, that I know I can just measure for length. But, is the diameter 1/4 inch and I am not sure about the bends at the end? Thanks.
Drew
DrewP #741227 04/21/2011 2:10 PM
Oh, I think we've got the bases covered on the original question so I wouldn't think that you're stealing the thread.
But, twernt me you're thinkin' of Drew, how so ever, I can post the dims if you want them.
http://www.pbase.com/dennygraham/image/134099325/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Excellent! I wish I had as much initiative as you Denny to document my restoration so well. You have certainly become a
"Go to guy" on Stovebolt. Thanks.
Drew
DrewP #741246 04/21/2011 2:44 PM
Yo welcome, hope it helped.
DG
Denny G
Sandwich, IL
That's it! My spring is missing one of the hook arm sections, so I don't have an overall length. The pix will help for when I reassemble my seat. Thanks for your help Denny!
P.S. Was the 16" dimension measured when the spring is stretched or compressed?
Don't know what ya mean by "hook arm section" and the length is in the free state.
DG
Denny G
Sandwich, IL
The part of the spring that isn't coiled up, but straightens out and has a hook at the end. One of the "hook" sections on my spring is broken off.
You could also use a shorter one and bend a link up out of some 1/8" rod to make up your length as they do with the brake springs.
DG
Denny G
Sandwich, IL
Moderated by  ndkid275, Phak1
