6 members (wvstovebolt, Leo, TUTS 59, Red75bronco, dt235sd, 1 invisible), 79 guests, and 3 robots.
Topics128,129
Posts1,056,697
Members48,454
Can anyone tell me where to find wire connectors to fit the pin posts for 55-59 fuel and temp gauges?
lifestoshort
I've never seen them available seperately, although I believe some of the wiring harness makers use them, might try one of them, like EZ wire
Rick -
I couldn't find them either, so I just used the female end of a bullet connector. I had to open it up a bit to fit over the pin, so I just used 1/2 of the tip of a needle nosed plier. Worked great and has a nice tight fit.
Chris
