| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73887 02/26/2007 1:21 AM | Joined: Feb 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 42 | Hey has anyone taken the lower crank shaft pulley with the dealyo for hand cranking and vibration damper off on a 1942 6cyl-235 ? I want to paint and would like to get behind it to clean the block. | | |
#73888 02/26/2007 1:27 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | A simple search with the title of this thread gave me this one, Good Luck | | |
#73889 02/26/2007 3:08 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | When you get the pulley off you might find a slight groove in it from where the timing cover seal rubs. You can get a Speedi-Sleeve from an auto parts store which fits right over it and eliminates the problem. | | |
