| | | Forums66 Topics128,076 Posts1,056,008 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 13 New Guy | | New Guy Joined: Sep 2010 Posts: 13 | I have a 65 chevy pu which I got with no engine I put in a 250 6 cyl and need some help on the basis wiring to ing. switch I have run a wire to the coil from the starter and from the coil to dist. when I use a push button remote starter it lights up on both sides of the coil. but now to get it to the ing. switch is the next challenge any help? out there? Thanks, jerry in tn. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Jerry;
Google is your friend. Just enter 1965 chevy truck wiring diagram and 827,000 responses show up. Go to Google Images and you will see several wiring diagrams. Good Luck.
SimS | | | | | Joined: Jan 2010 Posts: 10 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 10 | Does your truck have the engine compartment wiring harness that connects at the horn relay, alternator, and voltage regulator then runs to the firewall connection? | | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 |
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
| | | | | Joined: Sep 2010 Posts: 13 New Guy | | New Guy Joined: Sep 2010 Posts: 13 | Hello, Yes The alt & regulator wiring haress is all there and I connected it up. I need the starter coil side but most important whic wires go to the key switch as i have no factor harness there. Thanks, Jerry | | | | | Joined: Jan 2010 Posts: 10 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 10 | I think the Ignition switch is like this:
brn/w - Voltage regulator 4 ppl - direct to Solenoid S p - goes all over the place including Solenoid R (may turn into a white or ppl wire at sol) r - fuse panel power
I'm guessing you're not much into the wiring diagrams but as suggested you may want to find one and take a look. Finding a factory harness might also be a good idea. Good luck. | | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 |
