7 members (TooMany2count, Wheelie, Stovebolt48, Napco Mark, baldeagle, RaNfLaS, Jeff Ogden),
72
7
Mod | | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73867 02/25/2007 5:02 PM | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | I have a 1951 Chevy 3604 with original 216 in it. I will be reinstalling the newly painted draft tube before too long and would like some suggestions on installing it without scratching up the fine paint job. I was planning on using a rubber mallet and some TLC. I couldn't find any info. in the search option. Any other or new suggestions? Thanks, Jeff. | | |
#73868 02/25/2007 5:20 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If its all cleaned up I don,t think it will be that hard to get in. A piece of wood on top & a little tap ought to do it. Then put the bolt in the bracket. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73869 02/25/2007 6:13 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Maybe throw a couple of shop rags between the wood block and the tube as an added precaution to keep the paint from being scratched as well.
Bill Burmeister | | |
#73870 02/26/2007 2:06 AM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | i put a light coat of rtv sealant on mine . helped lube it & stop any leakage . ( rubber mallet & tap lightly , it should pop right in . ) | | |
#73871 02/26/2007 5:31 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | put in freezer for about 20 min I would then take my shoplight and put close to the hole so that the heat from bulb would warm the hole area.Tap in with a rag covered wood block untill bracket hole lines up. | | |
