4 members (55shaker, WICruiser, baldeagle, Napco Man), 100 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#73867 02/25/2007 5:02 PM
I have a 1951 Chevy 3604 with original 216 in it. I will be reinstalling the newly painted draft tube before too long and would like some suggestions on installing it without scratching up the fine paint job. I was planning on using a rubber mallet and some TLC. I couldn't find any info. in the search option. Any other or new suggestions? Thanks, Jeff.
#73868 02/25/2007 5:20 PM
Riding in the Passing Lane
If its all cleaned up I don,t think it will be that hard to get in. A piece of wood on top & a little tap ought to do it. Then put the bolt in the bracket.
1972 Chevy c10 Cheyenne Super
#73869 02/25/2007 6:13 PM
Maybe throw a couple of shop rags between the wood block and the tube as an added precaution to keep the paint from being scratched as well.
Bill Burmeister
#73870 02/26/2007 2:06 AM
i put a light coat of rtv sealant on mine . helped lube it & stop any leakage . ( rubber mallet & tap lightly , it should pop right in . )
#73871 02/26/2007 5:31 AM
put in freezer for about 20 min I would then take my shoplight and put close to the hole so that the heat from bulb would warm the hole area.Tap in with a rag covered wood block untill bracket hole lines up.
