2 members (1955 1 Series, Hotrod Lincoln), 148 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#73861 02/25/2007 4:57 PM
Does anyone recommend a specific gasket sealer to use on my 216 side cover. I have a 1951 Chevy 3604 with original 216. Any other suggestions or advice are greatly appreciated in advance. Thanks, Jeff.
Riding in the Passing Lane
I like to glue the gasket to the cover with weatherstrip adhesive & let it dry good. I then put a thin film of rtv on the lower edge.
1972 Chevy c10 Cheyenne Super
Ex Hall Monitor
Ex Hall Monitor
And don't be really sad if it still leaks a bit. Old Chevy sixes and old Harleys have a lot in common. If they ain't leaking oil they're out of oil. grin
Quote
...and like old Harleys, they ain't leakin', they are just markin' their territory.
Thruwurkin
Half Ton Will Travel
God bless America...One nation under God
Ex Hall Monitor
Ex Hall Monitor
wink grin
I've only stuck gasket to sheetmetal and let set.Never used any between gasket and cast iron.Tighten after engine has been warmed.Never had a leak.
