7 members (Gdads51, dt235sd, moparguy, Otto Skorzeny, tclederman, Jon G, 1 invisible),
86
Mod | | | Forums66 Topics128,094 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The external plumbing is just the normal line routing for a bypass oil filter. All stovebolt engines, even the dipper types, have an oil pump. He might have had the engine converted to pressure-lubed rod bearings, but the oil pan would have to be removed to check on that modification. Jerry
| | | | | Joined: Apr 2011 Posts: 12 New Guy | | New Guy Joined: Apr 2011 Posts: 12 | Would the oil pressure when it is running give me an indication? | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Maybe, but the only way to be certain is to drop the pan, look for dippers on the rods, and remove at least one rod cap to see if insert bearings have been installed. The crankshaft journals will also have an oil passageway drilled into them if it's been converted to pressure oiling at the rods, and the troughs in the pan will be removed. Jerry
| | | | | Joined: Apr 2011 Posts: 12 New Guy | | New Guy Joined: Apr 2011 Posts: 12 | So I put the new fuel pump on and got the truck running on its own. I didn't let it run very long though because it needs a water pump and the carb was leaking as much fuel as it was putting in the engine. But it ran and idled on its own.
The good news is that the oil pressure gauge was pegged at 30 psi.
The bad news, it has a pretty nasty knock. Not sure what thats all about, any ideas? I figure I will have someone with a little more knowledge about these trucks come take a look. Hopefully it isn't to bad.
Thanks, Chad | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Hello The FAA serial number indicates a 1948 Passenger Car 216 built in Flint, MI. per: this. So apparently the motor was swapped at some time which is not unusual - a lot can happen in 60 years. I agree with Jerry, you will probably have to pull the oil pan and look for the dippers and troughs to know what's been done.
Professional Novice
| | | | | Joined: Apr 2011 Posts: 12 New Guy | | New Guy Joined: Apr 2011 Posts: 12 | So I pulled the valve cover and found that there is a bent rod. As I spin the rod you can hear the same knock.
I got a dumb question. How can I spin the engine by hand? The water pump is siezed so I really only have the crank to work with but a quick look at the crank didn't show any easy way to get a socket on it to spin it around. | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | I think the easiest thing to do is remove all the spark plugs (so you're not turning against compression), then use the fan blades to turn the engine. You usually have to push down on the belt with your other hand to prevent it from just slipping, but it usually works.
BTW, don't forget to take it out of gear first, like I did once . . . DOH!
-Michael | | | | | Joined: Apr 2011 Posts: 12 New Guy | | New Guy Joined: Apr 2011 Posts: 12 | Yeah, the fan blade trick isn't going to work on this one. The pump is siezed up so the fan doesn't move. I had to take the belt off to test fire it. I may just have to turn it a little at a time with the starter. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Put the transmission in high gear, and pull the spark plugs. Gently roll the truck forward or back, and the engine will follow. We used that method to adjust valves and do other chores requiring turning the engine in the pit area of round tracks for many years. Jerry
