3 members (TUTS 59, 78buckshot, Gazz), 111 guests, and 3 robots.
Topics128,093
Posts1,056,475
Members48,444
Will a flexplate from a 87, 350 TBI fit an inline? Need to know if I change the V8 out for an inline six if I have to get a different one or not. I have a 700R4 trans. Thanks! H.
Riding in the Passing Lane
No it wont work. 86 up small blocks have balance weights. 85 on back will fit. Be shure to check to see if it will fit the converter before you install it. It probably will but it,s a good idea to make shure before yuou put it together.
1972 Chevy c10 Cheyenne Super
Hey Wrenchbender, I really appreciate the info. I thought that maybe there might be a problem. Wasn't too sure. If I decide to change out the engine I'll look for an 85 or older small block or a flexplate from an inline before installing it. I think the torque converter will work. I hope so. Its a new stage 1 converter. Beefier than the stock one. I'm supposed to have that installed tomorrow but can't get the trans shop on the horn. May be closed due to bad weather we have had. I like the pics on your trucks. Very nice! Thanks again........Henry
Hey Henry, exactly which inline are you dealing with? They are not all the same...
Oldsub is right. It won,t fit the 216,235,or261,s. The 292,s except for the real early ones had larger bolt holes. The flywheel/flexplate can be drilled out for this.
