| | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | Anybody know what the torque spec is for the flywheel to converter bolts on a th350 tranny?? also there is a small hole in the top of my crank vent tube are they all made that way for a reason or did someone just do that for some unknown reason 50 years ago?? just wondering. I'm rigging up the tube to the auto tranny case. | | | | | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | They're 7/16-20 bolts, so 55-65 ft./lb. will work. Normally, there's a plastic vent with a loose-fitting cap near the top of the case to keep bugs, etc. out of the trans case, or a small piece of steel tubing with a 90-degree bend in it. Unless you're planning to go off-roading and get that part of the transmission case submerged at times, I see no reason to attach anything to the case vent. Jerry
