5 members (55shaker, FAST55, WICruiser, Rusted Nut, MickeyP), 179 guests, and 3 robots.
Topics128,078
Posts1,056,051
Members48,433
After taking off my oil-bath air cleaner the other day and discovering the carb throat was absolutely filthy, I decided I wanted to figure out a way to convert to a regular paper filter. Turns out, it was really easy. I bought a Carquest 88094 air filter. It's about 8.25 inches in diameter and about 2.25 inches in height. A shorter one might work better, but I couldn't find one. I ended up having to drill out and replace the threaded center stud to make it longer, but that was the only modification.
Anyway, here's the finished product. Hopefully, this may help someone else out some day.
http://img171.imageshack.us/img171/4422/aircleaner.jpg
I was just looking at my old oil-bath cleaner wondering how I should mod it for a new paper filter...now I don't need to...thanks!
If you have the standard wire mesh type filter, rather than the optional oil bath type, its an easy conversion. I didn't, so I found a wire mesh type at a swap meet (from a Studebaker, no less)
and used a paper filter in it. Well, on the NEXT truck, I'll know
how to convert one. Thanks for the tip!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
