15 members (Jims46, Southerntruck, joe apple, Otto Skorzeny, Hawkman, J Lucas, D B Cooper, Oldcaliforniakid, Stovebolt48, Bill Hanlon, Peggy M, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 1 invisible),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 12 New Guy | | New Guy Joined: Apr 2011 Posts: 12 | Before we had intermittent spark. Changed the condenser and points. Still nothing. We tested the ignition switch and the test light lighted, that means the ignition switch is O.K. (I'm assuming) We tested the coil as well, and it works. I'm beat, where should we go from here?
Thank you in advance!
Starting to get frustrated with this truck that previously ran like a top.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Check the distributor side of the coil wiring with the test light. When the points are open, the light should be on. When they close, the light goes out. It's a common mistake to get the connector that goes through the side of the distributor grounded, resulting in the same symptom as if the points were staying closed all the time. Jerry
