| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I have been trying to find out if I should use an additive to my oil or not. There doesn't seem to any agreement. Has anyone had and experience with Classic Car Motor oil? They claim it's the one. http://www.classiccarmotoroil.com/
It seems too good to be ..... Thanks Peter | | | | | Joined: Sep 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 46 | run a good 10 w 30 oil and you will be fine ran mine for 30 years like that and it still runs fine | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you have a stock-mild performance engine that is properly broken in, you will be fine with regular motor oil without any additives. Use a quality brand oil, like Valvoline or Castrol. If you have a fresh rebuld, Rotella would also be good to use.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | where do you get rotella? The only place I have seen it is in the phillipines and thailand, but then again I have never looked for it. Is it an eastern US thing? certainly is weird how mention of a motor oil can bring back those memories... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | here in the southeast you can find it at any of the parts houses. If none of yours have it then go to a place that services the tractor trailer rigs. | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | Peter H, Like Superfly I have a Babbit Pounder 216 and have over 100,000 miles on it and have used a High Grade 10-30 since the start. So far it still runs great. I change my oil every 60 days regardless of the mileage. Oil is cheaper than any failures. I buy it by the case and shop sales. Normbc9 | | |
